rogbell | -- 10-19-2012 @ 3:39 PM |
I have a 1953 Victoria that has a C-6 transmission installed. Can I use the original speedometer and if so, what do I need to do? What parts do I need and where can I buy them? Thanks.
Stroker | -- 10-19-2012 @ 4:15 PM |
rogbell: Yes, you can (and should) use your original speedometer. Various companies make adapters, some you can adjust for odd-ball rear axle ratios. I did a quickie Google search and came up with one http://www.abbott-tach.com/ I'm sure there are others, as lots-o-street rods use aftermarket transmissions. This message was edited by Stroker on 10-20-12 @ 7:24 AM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5322 |
