rogbell | -- 10-05-2012 @ 11:47 AM |
Looking for a source for a power brake booster for my '53 Vic. Have converted to disc brakes and dual master cylinder. Thanks.
supereal | -- 10-05-2012 @ 1:59 PM |
The type of booster will depend on the kind of master cylinder you have installed for your conversion. For ionstance, Jegs offers a firewall mount kit, and some OEM boosters. Their number is 800/345-4545. Chassis Engineering has "power brake adapter" (part# AS-2075), and an adapter that fits the Ford two bolt pattern. Their number is 319/643-2655. Suppliers tend to be leery about conversions due to liability exposure.
trjford8 | -- 10-05-2012 @ 7:41 PM |
Check with ECI, Master Power. or Jamco. All can be found on the web and have the correct boosters and master cylinders for your '53. I suspect you will wind up with a Corvette master cylinder, a 7" dual diaphram booster and a brass combination valve for your set up.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5278 |
