flathead48 | -- 10-03-2012 @ 12:15 PM |
Since you can't see the center Bearing, is there any sure way, short of assembly and road test, to tell if it is good . Thanks, Rick
40guy | -- 10-03-2012 @ 12:40 PM |
If it's not making any funny noises; my bet is it's o.k. Don't forget to grease it . There is a fitting on the torque tube for this.
alanwoodieman | -- 10-03-2012 @ 12:43 PM |
if the driveshaft is out of the torque tube, look for any marks on it-worn down? which would indicate a bad bearing
flathead48 | -- 10-03-2012 @ 5:21 PM |
Thanks guys for the info
supereal | -- 10-03-2012 @ 9:16 PM |
The grease fitting at the center of the torque tube secures the bearing collar, so be careful if you remove it. Replacing the bearing requires a special rig, so if it isn't making noise, I'd leave it alone.
flathead48 | -- 10-04-2012 @ 5:13 AM |
Guys, appreciate all the input, I picked up a complete rearend with tube I didn't want to do anything with the tube unless I could check out the center bearing to see it was ok, sorry I didn't explain my self better.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5270 |
