MOXIE | -- 12-31-2009 @ 2:55 PM |
I need complete wiring for my 35 coupe. C&G has a 15% special on wiring which brings their price down to about what MAC's sells their wiring. I would think the quality is the same but what do you guys think. Or is there a better place to purchase wiring.
ford38v8 | -- 12-31-2009 @ 6:48 PM |
Moxie, C&G is good. Rhode Island Wire is good. Specify soldered connections, not just crimped. Alan
trjford8 | -- 12-31-2009 @ 9:09 PM |
I've always had good luck with C and G Parts. They carry parts that are good quality as they want return customers.
supereal | -- 01-01-2010 @ 7:31 AM |
I second Tom's recommendation. There is a serious problem with cheap wiring, as the looms are made up with unnecessary connections to allow it to be used in a number of vehicles, which is confusing, as is the failure to adhere to the correct color codes.
37RAGTOPMAN | -- 01-03-2010 @ 3:33 PM |
I used RHODEISLAND wiring and would use nothing but, and made in the USA, just did my 37 last spring, I doubt you would have any problems with there wiring,all solder connections,correct size guage wiring and color on the wiring, and comes with a wiring diagram hope this helps,37RAGTOPMAN
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=526 |
