sunflower | -- 09-18-2012 @ 7:38 AM |
Is changing the wishbone ball a big job do I have to support or jack up anything under my 35Ford? Thanks sunflower
trjford8 | -- 09-18-2012 @ 8:10 AM |
Not a big deal. Take off the cap and then wedge a block of wood between the frame and the wishbone. This moves the wishbone down enough so you can remove the old ball and install the new one.Use some dish soap to lube the ball and the new rubber, it will install much easier.Pull the wood block, reinstall the cap, and you are good to go.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5214 |
