Steves46 | -- 09-14-2012 @ 5:57 AM |
For those using turn signals, are your wires connected to the flasher through a plug-in socket or directly to the prongs? I suspect if I wanted to use a socket to prevent any possible shorts, the standard headlight type would work or I could just wrap e-tape around each prong.
51f1 | -- 09-14-2012 @ 6:44 AM |
You could solder the wires to the flasher, but a socket is better. If you use the socket, it'll make it easier to change flashers, and the flashers do go bad. Here's a picture: http://i250.photobucket.com/albums/gg264/rcrispd/turnsignalsocket.jpg You could use a headlight socket, if it fits. Richard This message was edited by 51f1 on 9-14-12 @ 6:47 AM
Old Henry | -- 09-14-2012 @ 6:47 AM |
I use the socket. Then it's easier to replace the flasher when needed. Socket with pigtails can be bought at any auto parts store. Old Henry (The older I get, the better old looks.)
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5195 |
