Fred Hanks | -- 09-06-2012 @ 2:32 PM |
How do I bench test a 6volt amp gauge for a '51 car v8?
supereal | -- 09-06-2012 @ 5:24 PM |
Using a six volt battery, place the ammeter in series between the poles with a load in the circuit. A headlight bulb works well for that purpose. If the needle swings when the wire is placed across the battery, it is likely the gauge is OK.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5163 |
