johnmyron | -- 09-06-2012 @ 11:45 AM |
Wiring up the dash for my 53 Sunliner-converted to 12V. Using voltage reducer for gauges, except for ammeter. Polarity is reversed to negative ground, am using an alternator as well. Is there a way to make original ammeter function? If the induction will work, do I need to reverse the direction the wire goes thru the induction loop? Any of you gauge geniuses our there. thanks John Wells
carcrazy | -- 09-06-2012 @ 12:40 PM |
The original ammeter will work just fine. Simply reverse the induction wire so the gauge will read charge and discharge correctly.
Fred Hanks | -- 09-06-2012 @ 2:22 PM |
how do I bench test the amp gauge for a '51 ford car fv8 ???
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5158 |
