Topic: 1953 VIC REMOVING REAR ASHTRAYS
rogbell    -- 08-16-2012 @ 12:32 PM
  How do you remove the ashtrays in the rear quarter panel trim in a 1953 Victoria? I would like to clean and refinish them. I don't want to have to remove the trim if It can be helped.
trjford8    -- 08-16-2012 @ 7:51 PM
  Those ashtrays should pull out. Push the lid back as far as it will go and then pull on the ashtray. You may have to "rock" them a bit as they could be stuck from dirt and rust. They were designed to be removed in order to empty them.
TomO    -- 08-17-2012 @ 2:48 PM
  Try pushing down on the cigarette snuffer (the round projection), that should release the ashtray. The frame is probably held on by a screw.
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5075
