Topic: Ignition Switch
bo8109b    -- 08-08-2012 @ 6:45 PM
  The ignition key in my '48 tudor cannot be turned left to the accessory positon. Does fixing it require a replacement cylinder and if so can the new cylinder be rekeyed to the old keys? Carl
TomO    -- 08-09-2012 @ 8:37 AM
  It may be the switch itself that is causing the problem. A new cylinder would probably not fix the problem. The cylinder just determine which key can turn it.
A new cylinder can be re-keyed by a competent locksmith if he has the pins.
I would remove the cylinder and check out the switch.
supereal    -- 08-09-2012 @ 8:52 AM
  The ignition switch in the '48 is an odd piece, as it was used only that year, and came in later production. I'd recommend replacing the entire switch, as C&G (800/266-0470) shows it as LH-9578 for under $30,with two keys, while the cylinder and keys, alone, is listed at $75. The door and ignition keys on my '47 are not alike, but haven't posed a problem with both on the key ring. The enemy of all ignition switches is the use of a heavy key ring. It damages the cylinder and pins. Two keys and a light tag will protect the lock.
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5040
