DEAN333 | -- 08-08-2012 @ 7:16 AM |
36 with Stromberg 97: I put in a carb kit from C&G, had the top of the fuel pump off to clean slight sediment and valves. The car will only run 15-30 seconds with gas poured in the carb. Pump lost prime? Did I put valves in pump back wrong? I put the valve with the cone facing down in the deeper hole and the cone facing up in the short hole of the pump. TIM CARLIG
TomO | -- 08-08-2012 @ 7:53 AM |
Tim, The valve closest to the pump outlet, should be installed so that the flatter surface is visible and the other valve is installed with the cone up. It sounds like you have them correct. Operate the pump by cranking the engine or by hand and check for vacuum at the inlet port and pressure at the output port. This will tell you if you have the valves installed correctly. If your valves are installed correctly, and the pump is operating when the starter is engaged, you might have a vacuum leak on the input to the pump. This can come from a leak in the flex line or a leak at any of the connections or at the top of the fuel pump. Tom
ken ct. | -- 08-12-2012 @ 6:22 PM |
Pump valves/ sounds like you dont have the correct FP for a 36 late or early. 36 pump dont have valves like you discribe [encased in a brass housing] #6 have a phonlic 6 sided disc,with a small spring under or over them. I have the correct pumps and or valves you need. Call me 1-203-260-5945 torrow as im about ready to hang it up for the nite. ken ct.
DEAN333 | -- 08-13-2012 @ 5:53 PM |
Thanks Ken but I already ordered a new pump from Drake as I couldn't tighten the bolt on the pump cover. I tried running a tap to clean the threads but still could not tighten the bolt sufficiently. TIM CARLIG
TomO | -- 08-14-2012 @ 7:39 AM |
Tim, the fuel pump from Bob Drake will not be correct for a 36 car, but this is only important if you are going to have the car judged at an Early Ford V-8 Club National Meet. Tom
DEAN333 | -- 08-14-2012 @ 7:56 AM |
Why is the Drake pump not correct? Looked right in the photo. Who has the correct pump? I thought he was a club member selling correct stuff. TIM CARLIG
DEAN333 | -- 08-14-2012 @ 7:03 PM |
Some pics of the fuel pump valves and the pump as it looks in place. TIM CARLIG
DEAN333 | -- 08-14-2012 @ 7:05 PM |
The pump...... TIM CARLIG
TomO | -- 08-15-2012 @ 7:38 AM |
Tim, Bob Drake and other vendors that sell new fuel pumps sell the version that was used on the 41-46 cars. The inlet and outlet ports are on the same level and the cover has little projections to help line it up. Here is an excerpt from my article on fuel pumps in the V-8 Times: The 68-9350 (fig 2.) was introduced in late 1936. This pump was used from 1936 though 1940. It has a larger 2 1/4" body diameter, the top is more rounded. The outlet port is still 1/4" lower than the input port. The parts catalogs up to 1940 show this pump with the hex head sediment bowl drain. The 1940 catalogs show this pump with a petcock type wing nut drain. I am not sure when this type of drain was introduced. The 41-46 pump works fine on a 36 car and has a better valve arrangement than the 36-40 fuel pump and is my preference for Touring Class car. Tom
ken ct. | -- 08-16-2012 @ 8:41 AM |
36's used 2 diff pumps / early 36 used a small domed pump 2" across the top and a late 36 used one 2 1/4 across the top. Has inlet and outlet openings off-set by 3/8" and top has no indexing tabs [4] on the top.Also a "T" handle petcock to drain. I have all kinds of the Ford pumps in rebuilt form on original pumpe. All pumps sold by the big-box vendors come in from China.Buy usa stuff/ ken ct 1-203-260-5945 cell
ken ct. | -- 08-16-2012 @ 8:44 AM |
It also depends who's looking at Drakes pic in the catalog,he has what is called universal pumps. Do you know what a correct one looks like??? ken ct.
DEAN333 | -- 08-16-2012 @ 3:45 PM |
Ken, I looked at the photo in the 35-36 Ford book, page 103. I sent you my pump to rebuild today. TIM CARLIG
DEAN333 | -- 08-16-2012 @ 3:48 PM |
My pump and the picture on Drake's website look like the Ford book [from V8 Club] photos. TIM CARLIG
TomO | -- 08-16-2012 @ 5:12 PM |
Here is a photo of the late 36-40 fuel pump. The pump that you had photo of is the 41-46 universal style. Tom
DEAN333 | -- 08-16-2012 @ 5:55 PM |
The next 3 posts have pics of the 5/16 hex bolt with the center drilled out and a brass plug inserted. It was mounting my fuel pump to the stand on the driver's side. I am wondering why the bolt was drilled out as I don't believe it is original. TIM CARLIG
DEAN333 | -- 08-16-2012 @ 5:58 PM |
Pic #2 TIM CARLIG
DEAN333 | -- 08-16-2012 @ 5:59 PM |
Pic #3 TIM CARLIG
DEAN333 | -- 08-16-2012 @ 6:02 PM |
Ken ct.: I guess my pump in the 41-46 universal style. Will you be rebuilding mine or sending me the correct pump for 1936? TIM CARLIG
TomO | -- 08-18-2012 @ 8:51 AM |
Tim, The drilled out bolt looks similar to the one used for the oil filter return line in the 39-40 Fords. Tom
DEAN333 | -- 08-18-2012 @ 11:49 AM |
So is that where I would connect an oil filter return? TIM CARLIG
ken ct. | -- 08-21-2012 @ 6:35 PM |
Tim,that is a fitting to return line from the oil filter..Wish i would have noticed the fillstand is accually from a 34 not 36. I would have traded you for proper one plus a few bucks.If interested call me. ken ct.Did you get the pump yet.
DEAN333 | -- 08-21-2012 @ 8:37 PM |
Ken, It's Tuesday nite, I expect the pump tomorrow. Do you have a pic of the correct fuel stand? P. 104 of the 35-36 Ford book shows it from the right side, hard to tell for me if mine is wrong. Are you sure you have no use for the 2 '47 pumps I have? I'll call you wednesday. Do you have the air scoop breather? TIM CARLIG
DEAN333 | -- 08-22-2012 @ 7:14 PM |
I put rebuilt pump on tonite, starts and runs but leaks gas through accelerator pump shaft opening. Friend told me to lower float level, did that and still leaks. Attempted to lower float some more but now accelerator pump leather was curling on one edge when reinstalling top of carb so I have the cardboard ring that came on the pump holding it in place for an hour or so with a few drops of MMO to let it regain it's shape. TIM CARLIG
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5036 |
