MICHV8 | -- 08-06-2012 @ 7:36 PM |
I have a 34 trans with no mount supplied. The repro rubber doughnut mount (Drake, MACS, etc) doesn't look to be what I need. Is the cast piece with ears and inner u-joint cap available anywhere? Thanks for your help.
fortyfordguy | -- 08-07-2012 @ 6:07 AM |
Not sure what you mean by "cast piece with ears". The 1934 rear support (40-5089 was a heavy steel stamped part with the rubber ring vulcanized to it). We sell this repopped part and have for several years w/o problems. The inner cap (B-4513) and the split outer cap (B-4520) are available from our used parts inventory. There are two other parts in that mix....the B-7085 rear bearing retainer (a casting) and the B-5099 rear plate...plus the four special L head bolts. We stock that stuff too. Mac VP VANPELT SALES LLC www.flatheadv8.com
MICHV8 | -- 08-07-2012 @ 7:18 AM |
I had a couple rear supports off other trans (one was a 36) and they were complete units with ears, but the wrong width. I assumed the 34 trans had the same setup. Anyway, thanks for the help and I'll give you a call today.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5030 |
