Topic: Model 94 Carb
Big Red 51    -- 08-01-2012 @ 5:55 AM
  Anybody having fuel pressure problems with the new Airtex 9597 double action fuel pumps. Mine is reading about 5 lbs and , therefore, no fuel flowing thru the 94 carburator. Kenct has said no more than 3 lbs. I hate to have to put a regulator on the pump to carb line mainly for show reasons and points. It seems Airtex is using either a too strong spring are stiff rubber in the pump "Made in the USA". Any thoughts? Thanks Don
TomO    -- 08-01-2012 @ 6:55 AM
  Return the fuel pump as defective. KenCt is correct. If you have had the pump too long, you can change the diaphragm return spring.
I have had good luck with the Offenhauser fuel pumps sold by Speedway Motors.
Big Red 51    -- 08-01-2012 @ 2:23 PM
  Thanks Tom. Kyle at C&G said no problem returning. Problem is getting a pump that works correctly. Most houses discontinued the dbl action rebuild kits. Then&Now in Mass rebuilds the dbl pumps but don't have a means to check the output pressure. Maybe that's why so many are running electric pumps with regulators.
I'll check out the Offenhauser pumps.
40 Coupe    -- 08-02-2012 @ 6:28 AM
  I believe both KenCT and Charlie sell rebuilt and tested fuel pumps, they do their own rebuilding.
Big Red 51    -- 08-02-2012 @ 9:17 AM
  Ken said he does not do double action pumps any longer.
TomO    -- 08-02-2012 @ 9:23 AM
  I am sorry, I missed the double action part of your message. Go to RockAuto.com and order the Carter fuel pump. I have heard that they work better, but some people have had trouble with those also.
ken ct.    -- 08-16-2012 @ 8:55 AM
  Put a single action pump on it. ken ct.
Model B    -- 08-16-2012 @ 4:31 PM
  If you are still at 6 volts, I would recommend the Airtex E8902 low pressure electric inline pump. It is rated at around 2-5 lbs for vintage vehicles. No regulator necessary with it either. I use mine for priming and vapor lock conditions. Or, like Ken indicated, go to a single action if you don't need the extra vacuum. Good luck, Pat
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5008
