MG | -- 07-26-2012 @ 3:59 PM |
I'm repacking my front wheel bearings on the '37 and relacing the inner seals. When I tap in the inner seals, do I stop when they a flush with the drum casting or do I tap them in until they are stopped by the inner bearing?
40guy | -- 07-26-2012 @ 4:12 PM |
I always do them flush with the drum. A block of straight wood works good for this. I place the wood across the seal/drum to insure it is a uniform fit all around.
MG | -- 07-26-2012 @ 4:21 PM |
Thanks 40guy - thats exactly what I did but I was concerned about the depth of the seal. Flush to the drum it is then. Thanks again.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4981 |
