j.grif | -- 07-23-2012 @ 9:42 PM |
Saw a 48 ford pickup today,stock except for the 15 inch wheels. Looked good. I have a 36 ford coupe with 35 spoke 600/16 wheels. Was wondering what 15 inch wheel would work.. The truck owner said 39-40 mercury wheels or something like that. The only reason for change would be that there are more 15 inch tires available locally. Maybe.
juergen | -- 07-26-2012 @ 1:53 PM |
Since you have 35 wheels, you have a 5 bolt on 5 1/2 inch spacing. 15 inch wheels with this spacing were on early Mercury and late Ford vans/pickups. The early Mercs used hub caps which fit on the inside of the nubs (like 40-48 Fords). The later styles used caps which pressed over the nubs (like 49 up Fords).
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4970 |
