Topic: Brake bleeding
bo8109b    -- 07-13-2012 @ 8:30 AM
  Will the master cylinder allow the reverse bleeding of brake lines using a brake fluid pressure pot attachment to the wheel cylinder bleeder valves?
supereal    -- 07-13-2012 @ 9:22 AM
  The master cylinder has a residual valve that maintains pressure in the lines so you don't have to pump the brakes each time you use them. The brakes should be bled by using a "pressure pot" (bleeder) on the master cylinder. It has the added advantage of replacing the fluid in the master instead of contaminating it with old fluid from the wheel cylinders.
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4929
