DriverDan | -- 06-27-2012 @ 3:24 PM |
I have a standard 39 coupe restored to stock. The clutch slips, have lots of free pedal. Newly ground flywheel, disc, pressure plate. Maybe I did something stupid like reverse the disc (I don't think so). Main shaft of the transmission not throwing fluid-replace the seal. Any ideas how to figure this out? Thanks.
supereal | -- 06-27-2012 @ 7:05 PM |
When you say "lots of free pedal" how much is that? The proper amount is about an inch or slightly more. If you have more than that, it is likely due to a problem with the release bearing, it's fork, shaft, or linkage. The arms of the pressure plate move outward by centrifugal force as speed increases. That is why free pedal travel is required.
DriverDan | -- 06-29-2012 @ 5:22 AM |
Thanks Supereal. I set free pedal to 1 and 1/2 inches and the clutch slipped. Set it to about 2 and 1/2 and it didn't slip for about ten miles; now it slips like before. Not really sure what I should be looking for-everything as to the fork, release bearing, etc. looks good. If you have any ideas I would really appreciate it. Dan
deuce_roadster | -- 06-29-2012 @ 7:36 AM |
If the pressure plate is new (or even rebuilt) it might have been put together with the wrong or weak springs. It took me a long time to get over thinking that because something was new it was "good". I would think if your disk was in backwards the clutch wouldn't release.
TomO | -- 06-29-2012 @ 8:54 AM |
There is a small plate on the top of the transmission. Remove it and observe the action of the clutch mechanism. Your pedal should move about 1" before the throwout bearing contacts the fingers. Make sure that the throwout bearing holder flat spots are where the clutch release fork contacts the holder. Tom
DriverDan | -- 06-30-2012 @ 9:58 AM |
Any idea where I can find out which color of spring has more strength? I haven't found anything that tells. Thanks! Dan
supereal | -- 06-30-2012 @ 1:59 PM |
As a practical matter, replacing pressure plate springs is not a "do it yourself" proposition. Setting up a pressure plate requires a special fixture. In considering your problem, It is possible the pressure plate doesn't match the clutch disk. There are three clutch sizes used between 1932 and 1956, 9", 10", and 11", which is a truck item. The pressure plate and clutch disk must be matched in size. Having a 9" disk in a 10" pressure plate could account for your problem. When mounting a pressure plate to the flywheel, care must be given to bolt it down evenly by turning the bolts a bit at a time going around the perimeter of the plate. This prevents bending the housing. Most pressure plates are shipped with removable wedges that hold the plate back until it is in place, then they are removed. If they aren't removed, the clutch will not grip the disk. Given the fact that many parts vendors don't know what is correct for which vehicle, you may have been sold the wrong type. All pressure plates bear the number 7563, the disk, 7550. The 9" plate for your car carries the prefix 09A for the 9" plate with springs colored brown. If, by chance, you have a 10" plate, the springs will be blue. The disk will have a prefix of 91A when used with the 09A plate. Determining correct clutch parts can be difficult, given the large variety used. The only likely reason you are having the problem is that the wrong parts were provided, or the wedges were not removed. Over the years, clutches were often replaced, so the car may have received an improper one at some time. You will have to remove your clutch and check the numbers. This message was edited by supereal on 6-30-12 @ 2:03 PM
Stroker | -- 06-30-2012 @ 3:36 PM |
Super: I wonder just how many so-called "automotive machine shops" that exist today have the appropriate fixture(s) to properly set-up a pressure plate? We used to have one locally, but they converted their shop into additional "weekend-warrior" space to merchandise their growing inventory of "mouse milk"*. Driver Dan may have to send his pressure plate to a specialist such as Ft. Wayne Clutch in order to have anyone with a clue working on it. It is a growing trend, and a disturbing one in my book. Setting up a clutch is NOT rocket science, but you have to have the tools! *mouse milk: Products that promise to stop oil burning, tire cracking, paint fading, lifter noise, bad mileage, gear noise, overheating....ad-nauseum.
supereal | -- 06-30-2012 @ 7:48 PM |
Good one, Stroker. I think his problems don't center on pressure plate springs.. I'm betting on a parts mismatch. I have yet to see a faulty pressure plate, even though my faith in the integrity of new parts is not high. Nothing here adds up except the parts are wrong.
40 Coupe | -- 07-01-2012 @ 7:33 AM |
There has been a lot of problems with the new pressure plates offered by some suppliers. Your pressure plate should have three fly weights on the outside of housing. These weights increase the amount of pressure on the clutch plate by 3 fold when the RPMs are increased. The weights can be seen by removing the inspection cover.
DriverDan | -- 07-01-2012 @ 11:19 AM |
Thanks Supereal, you have given me lots of good info; I will have to remove the clutch (ugh!) and check it out. Dan
DriverDan | -- 07-01-2012 @ 11:24 AM |
Thanks for your advice 40Coupe, I will get to the pressure plate (no fun there) and check it out. Dan
DriverDan | -- 07-01-2012 @ 1:02 PM |
So I looked through the inspection hole and checked the pressure plate. It has no weights on the outside of the housing-I guess this is why the clutch is slipping, right?
TomO | -- 07-01-2012 @ 2:34 PM |
Before you start tearing it apart, observe the action of the clutch pedal releasing the clutch. The pedal should move and the fork should move the throw-out bearing toward the pressure plate. When the pedal has moved about 1/2" the bearing should be touching the fingers. If it touches the fingers before this, you do not have enough free play. Tom
40 Coupe | -- 07-02-2012 @ 3:38 AM |
There are other problems with some of the new pressure plates: The three fingers are too narrowly spaced and contact the end of the hub for the throwout bearing instead of the face of the bearing. This causes the hub to be ground down (lots of metal shavings)and the throwout to fail. Also the three fingers do not pivot properly, resulting in the pivot point wearing and too much play in the pivot. If you have an old original pressure plate with the weights and want it rebuilt I believe, Forte Wayne Clutch can do the job. Sorry I do not have their contact info.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4863 |
