Topic: Help with overheating
bmwillia    -- 06-25-2012 @ 6:08 AM
  Hi all!
My 33 is getting hot and I am looking for some help.
I have had my water pumps rebuilt by Skip Haney and I am currently in the process of cleaning the waterways out by using vinegar in the cooling system.
I ran the engine at idle for about 15min on Saturday and it started boiling over. I am noticing steam at the point where the exhaust meets the headers on both sides of the engine. Could this mean that there is a head gasket leak or is that normal for these ole flatheads?
I am running a stock non pressurized system.
Thanks!
Brad
Thanks!
Brad Williamson
TomO    -- 06-25-2012 @ 7:46 AM
  Are you sure that what you are seeing is steam and not just an exhaust leak?
Steam in that area would indicate a blown head gasket or a cracked block. If the head gasket is in such bad shape to show steam, you should see signs of a leak when the engine is cold.
A 33 V-8 usually has aluminum heads and I would not use an acid like vinegar to try to clean the block and radiator.
The first thing that I would do is to go to a radiator shop and have them pressure test your system for leaks. Do not let them use more than 6 lbs pressure for the test as it may damage your radiator. Next I would have them test for combustion products in the radiator, indicating a blown head gasket or cracked block.
If you cooling system passes those tests, remove the radiator and have it professionally cleaned.
bmwillia    -- 06-25-2012 @ 11:11 AM
  Thanks for the info Tom.
The flathead is actually a 35' model. Do they have aluminum heads?
Mine are painted and I can really tell what they are made of.
Thanks!
Brad Williamson
37 Coupe    -- 06-25-2012 @ 12:20 PM
  See if a magnet sticks ,if not it is aluminum.
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4847
