Topic: ?!
choupie    -- 06-23-2012 @ 8:39 PM
  Here's a head scratcher that y'all may be able to help me out with. I recently retrieved my 59a engine from the machine shop (they did alot of work - boring, grinding, balancing). When I went to put the cam shaft in today, I noticed that cam gear won't mate up with the crank gear. Although I'm perhaps no mechanical genius, the cam and crank gears seem to have the opposite pitch, such that I can't see they's mate up even if flipped around. I took pictures of the underside of the engine before I sent it to the machine shop, which should be attached to this post. Check out the orientation of the crank's gear. In a subsequent post, I'll post what it looks like today.
choupie    -- 06-23-2012 @ 8:41 PM
  Now, check out the orientation of the crank's gear in the photo taken today. It just doesn't seem like my cam gear fits anymore. Am I missing something?
deuce_roadster    -- 06-23-2012 @ 10:04 PM
  I suspect that maybe one of the gears is for a 59 series engine and the other gear is for an 8ba. Somewhere along the way they got mixed.
supereal    -- 06-24-2012 @ 4:12 AM
  Apparently they removed the crank gear, probably to grind and /or polish the crank, and replaced it backwards. You can confirm this by looking for the timing mark on the crank gear. It usually is a small dimple that matches the one on the timing gear. If it isn't there, the crank will have to come out.
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4838
