tudorbilll | -- 06-18-2012 @ 11:19 PM |
On my 53 Merc how many teeth on the speedo gear when i have 4/11 rear end ? I have to run 5 MPH faster reading to get the true speed. 55 realy is 50 mph. BILL
supereal | -- 06-19-2012 @ 5:52 AM |
The standard gear for 4:11 is 21teeth. Speedometer accuracy is affected by tire size and inflation, as well as condition of the speedo itself. Five percent variation isn't rare.
tudorbilll | -- 06-19-2012 @ 9:09 AM |
Thanks Super your a great help.
CharlieStephens | -- 06-19-2012 @ 12:33 PM |
If the speedometer needs repair and you fix the problem by changing the gear you will then have a problem with the odometer. Charlie Stephens
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4815 |
