daoust | -- 06-11-2012 @ 12:21 PM |
Re-paint engine, manifold and engine compartment components to correct colors Replace engine head nuts to cadmium plated Remove dual exhaust and replace single exhaust with all correct parts & hangers Remove electric fuel pump and line & replace with correct style Remove supplemental electric fan Remove voltage regulator and replace with correct style Remove water pumps for re-conditioning & re-install Remove oil bath air cleaner and replace with correct style Install new starter motor & bendix drive Install new starter solenoid Replace spark plugs wires with correct style Replace all spark plugs with Champion H10 Replace all radiator hoses Install correct battery ground strap Install new choke cable Replace radiator cap with correct style Paint exhaust manifold Replace cowl wire harness Replace wiper motor Install new wiper towers Replace wiper arms & blades Install correct brake bleeder valves Repair right front directional Remove and wood-grain dash, inner windshield trim, & window rails Re-paint steering column, energency brake, steering wheel, kick panels and kick-panel retainers to correct color Replace interior door panels with correct confuguration Replace all interior dash knobs Replace all interior door handles and cranks Replace trunk cardboard liners with correct blue-gray color Remove inner wheel trim rings & pinstripe wheels Tacoma cream Remove headlights and replace with "no-alignment tab" style Remove all accessories - grill guard, gas guard Replace quarter window weatherstrip Paint hub caps Bug all glass Find correct jack, base & jack handle David Daoust
supereal | -- 06-11-2012 @ 2:21 PM |
David: I didn't see a cooler listed so you can salute a good score, or lessen the pain of a bad one!
TomO | -- 06-12-2012 @ 4:36 PM |
David, I hope that you have the spark plugs with the black base. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4783 |
