williemcl | -- 06-06-2012 @ 1:58 PM |
Is there a good way to remove the adjustment tabs on headlight bulbs?
Stroker | -- 06-06-2012 @ 2:55 PM |
I've never tried to do this, but I would suggest taking them to a glass shop as they usually have wet grinders that should be able to remove them and leave a polished surface in their place.
supereal | -- 06-06-2012 @ 3:18 PM |
You can remove them with a fine stone in a grinder or Dremel tool. If they need to be polished, a knife sharpening stone will work. Just go slow, and take off a small bit at a time.
daoust | -- 06-07-2012 @ 6:10 AM |
Just FYI: Bob Drake sells them with the tabs already ground off. David Daoust
42merc | -- 06-07-2012 @ 6:48 PM |
I used a bench grinder with a 60 grit wheel, just don't get stupid, grind a little let it cool grind some more & in just a matter of minutes you are done.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4760 |
