Flatbob | -- 06-04-2012 @ 11:40 AM |
Does anybody have a part# for a replacement condenser that I could use at a local parts store?
supereal | -- 06-04-2012 @ 2:43 PM |
Many parts stores today don't even know what a condenser is. The mounting is important, and most modern condensers use a wire pigtail instead of the loop terminal common to old Fords. If you have the original three bolt coil, order an 18-12300 condenser from a good vendor.
fomocoloco | -- 06-04-2012 @ 10:43 PM |
I just got a IH-200 from NAPA. Will it work? I figured out how to mount it. Is there an advantage to the one you reccomend? weezer
kubes40 | -- 06-05-2012 @ 6:41 AM |
I have numerous NOS condensers for this application if you're interested. Mike "Kube" Kubarth
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4741 |
