bluemeanie | -- 05-26-2012 @ 6:45 AM |
Can anyone tell me the correct pathway for the taillight crossover harness on a '34 Ford 5 window coupe? What does it attach to? Thanks!
bluemeanie | -- 05-26-2012 @ 10:25 AM |
Just for reference, this is what I got from Fordbarn: I believe across the front upper edge of the fuel tank with two wire clips to hole it in place. Thanks Terry! According to the '34 chassis parts catalogue it was three B-14586 clips ( which makes sense given the distance covered). Thanks DavidG, I will check that out. I have some clips from Roy Nacewicz so I may already have them. They're the short version of the two-tooth spring clip. I went out to the garage and found them. They are exactly as you described and there are 3 in the pack. Roy's part nunmber is R-97-01. Thanks again to all.
BrianCT | -- 05-27-2012 @ 12:50 PM |
I pulled out an all original tank from a 34 last week and there were three clips as described. Brian
bluemeanie | -- 05-28-2012 @ 7:03 AM |
Thanks Brian. Are the clips on the tank so that the wiring goes across the top of the lip or hang from the bottom of the lip?
BrianCT | -- 05-30-2012 @ 10:52 AM |
Across the top.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4710 |
