parrish | -- 12-18-2009 @ 3:41 PM |
my generator is chirping a little from the pulley end...I did see the little cup on the other end and dropped a little machine oil into that side, but is there additional oiling for the pulley side? Thanks!
ford38v8 | -- 12-18-2009 @ 7:42 PM |
Parrish, The chirping will get worse to the point of pedestrians will jump back when it happens! You need a new bearing up front, and might as well put in a new bushing in the rear while you're at it. Make certain that the pulley nut is good and tight when you put it back on. Alan
supereal | -- 12-19-2009 @ 8:11 AM |
Also, be sure your belt is in good condition, properly tightened, and not glazed. A generator takes a surprising amount of power under load. Getting the pulley nut tight, as Alan mentions, is difficult when you try it with a wrench while holding the pulley. We use an air wrench for that job, and the pulley always stays in place.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=469 |
