norenovich | -- 05-16-2012 @ 5:48 AM |
i have an original 37 and i have rebuilt the waterpumps and they still leak. other than rebuilding them again is there any aftermarket pumps for the v860?? i see the 85hp has pumps that correct the leaking problem but they won't work on my 60hp. any suggestions would be great. thanks This message was edited by norenovich on 5-16-12 @ 6:47 AM
supereal | -- 05-16-2012 @ 8:40 AM |
We have found replacement waterpumps for the 60 at Little Dearborn in Minnesota (888/282-2066). Those pumps, both styles, bear no resemblance to the usual Ford pumps, and are nearly impossible to rebuild successfully.
norenovich | -- 05-16-2012 @ 11:11 AM |
Thank you for the advice. i live in mpls so little dearborn here i come.thanks again.
john38coupe | -- 05-19-2012 @ 8:10 PM |
Another source to discuss 60hp waterpumps is Bob Hall from Iron Station, NC. He has had good success with his reengineered pumps. (704-472-1700)
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4680 |
