martija | -- 05-15-2012 @ 9:16 AM |
Query, I bought a Bob Drake shock and sway bar kit for rear end and seams to be a huge interferance with the exhaust pipes (stock and added dual pipe). Is there a best solution??? reroute pipes or move upper shock mount inboard????
supereal | -- 05-15-2012 @ 9:43 AM |
The Drake rear shock kits I've seen use studs that that fasten to the cross-member for the top of the shocks.. If you can move those toward the center enough to provide clearance, that is probably your best choice. If not, a good muffler shop can custom bend a set of tail pipes that will solve your problem. Inclining shocks helps control body sway, but be sure you have enough travel.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4674 |
