Flatbob | -- 05-12-2012 @ 10:37 AM |
The studs that mount the swivels to the stabilizer bar, do they screw out of the bar or can they be pressed out; I see the stud has a slot for a screwdriver, so wasn't sure?
alanwoodieman | -- 05-12-2012 @ 10:42 AM |
tapered shaft-slot is for hold when tightening the nut
Flatbob | -- 05-12-2012 @ 12:00 PM |
Thanks Alan, Bob.
kubes40 | -- 05-12-2012 @ 5:56 PM |
The studs are Morse Taper fit. Once you remove the nut you'll need to hit them fairly hard to knock them out of the sway bar.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4661 |
