dclare37 | -- 05-05-2012 @ 3:58 PM |
Anybody installed a 37 car grille that can give me tips on how to get mine in? I didn't take it out so in the dark. Thanks, Doug 37 Tudor Hump
doning | -- 05-05-2012 @ 4:20 PM |
What kind of problems are you having?
dclare37 | -- 05-05-2012 @ 4:50 PM |
Have loosened off the cross bar in front of rad. And the inner aprons to frame bolts. And a couple of fender to frame bolts at the bottom. I can't seem to spread the fenders enough to get the grille in on both sides to bolt up? Should I be starting at the bottom on the horn panel and working my way up each side? Doug 37 Tudor Hump
trjford8 | -- 05-05-2012 @ 5:24 PM |
I loosened all the fender bolts that attach to the inner panels. Also I left off the inner braces that go from the inner panels to the frame. The fenders almost need to "flop" around to put in the grille.
dclare37 | -- 05-05-2012 @ 6:44 PM |
Ok will go for floppy fenders in the morning. Guess I didn't loosen up enough stuff. Took the braces off though. Thanks 37 Tudor Hump
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4637 |
