ebarras | -- 05-02-2012 @ 6:29 PM |
I have 1949 Ford Coupe, and the front clip is off of the car.Where can I find out screw and bolt sizes for the front end: fenders ,Radiator, inner fenders, ventilation boxes, radiator support, and grill? Thank You
MG | -- 05-02-2012 @ 11:05 PM |
Try FORDBOLTS, the eBay Store for ROY NACEWICZ ENTERPRISES, the premier supplier of authentic hardware to Ford Restorers. Whether your needs are for yourself, your customer or for the Judges, we are the way to go. http://www.fordscript.com/ford_bolts/products.html This message was edited by MG on 5-2-12 @ 11:13 PM
51f1 | -- 05-03-2012 @ 3:52 AM |
Look in a parts manual. They are all specified. Richard
TomO | -- 05-03-2012 @ 8:03 AM |
You will need a chassis parts manual for the 49 Ford, and even then, it can be difficult to find the correct size and finish of the bolts. There are 8 P/Ns for hardware under the fender for 1949, with no description of where they fit. That may not be all of the fasteners that you may need. You will also need a copy of the Standard Parts catalog that includes the 49 car. This catalog will give you drawings of the bolts, nuts, cotter pins, washers and clips. I would try to find a 49 car that has been restored and judged by the V-8 Club and take lots of photos with notes on the sizes and finish. If you can find a Rouge car (one that has been judged 90% original ) that would be even better. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4622 |
