Fordfan1 | -- 03-19-2012 @ 2:46 PM |
I am installing a set of 1937 3.78 gears in my 1935 differential.I need to know the correct side carrier bearings to use. The 37 unit uses a larger bearing, will they fit in the 35 housing? This message was edited by Fordfan1 on 3-19-12 @ 8:04 PM
ford38v8 | -- 03-19-2012 @ 7:04 PM |
I've been told that there will be a little machining to do for this swap. Alan
40 Coupe | -- 03-20-2012 @ 5:29 AM |
32-36 Carrier bearing (two needed) 18-4221 Timken 22168 37-47 Carrier bearing (two needed) 68-4221 Timken 25578 32-36 Carrier race (two needed) 18-4222 Timken 22325 37-47 Carrier race (two needed) 68-4222 Timken 25522 Check these numbers for the size needed at: http://www.timken.com/en-us/products/Documents/SealSpecGuide7533.pdf This message was edited by 40 Coupe on 3-20-12 @ 5:32 AM
supereal | -- 03-20-2012 @ 12:59 PM |
Unless you are building a car for show, consider adding an overdrive unit instead of a rear gear swap. The OD allows good low speed power, yet can easily reach hiway speeds. I've had one for about 15 years that gives me a 1/3 reduction in engine revs when engaged. That is why the Colunbia axle was so popular.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4484 |
