william | -- 02-25-2012 @ 2:49 PM |
Where can a guy get the M4664 type grease or it's replacement ? The auto stores think I'm nuts ( I might be ? ) I have read where the new slick grease will not work very good ? Bill
37 Coupe | -- 02-25-2012 @ 3:30 PM |
NAPA is where I bought the proper wheel bearing grease I believe especially for the rear wheel bearings. StaLub STL-SL3131. It is the old fashioned stringy fiber stuff. This message was edited by 37 Coupe on 2-25-12 @ 3:31 PM
ford38v8 | -- 02-25-2012 @ 3:31 PM |
Sta-Lube Heavy Duty Drum Brake Bearing Grease Available from Napa Auto parts part # SL-3131 Alan
william | -- 02-25-2012 @ 4:05 PM |
Thank You ,I give them a check on it .
supereal | -- 02-25-2012 @ 4:07 PM |
That is the only type of grease to be used in old Ford wheel bearings. The fibers allow the grease to be pulled thru the bearings as they rotate. Use of any other type of grease will result in damage to the bearing surface of the axle housings. Most, if not all, the greases listed in the old owner's manuals are now obsolete. There are acceptable modern lubes available, but avoid synthetics, aa they are designed for close tolerance applications, and our old Fords have, by comparison, very wide clearances that will not survive on an oil film alone.
Stroker | -- 02-25-2012 @ 4:37 PM |
AMEN!
william | -- 03-05-2012 @ 10:01 AM |
Hi Guys and Gals ! I want to thank all of you for your help about grease . Napa was one of the few places I could get Fiber Grease . It was not in there book ,But I told the guy to look at there wearhouse stock ? It was there 14 oz. tub under $6.00 .The LS 3131 number did it . Thanks Bill
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4375 |
