stevenwham | -- 02-12-2012 @ 12:37 PM |
Hello folks .. I'm a new member (in my USAF days I would be referred to as a "green bean"). I'm trying to figure out what I have. I recently bought a 35 five window coupe off Ebay. Of course, it was to some extent mis-represented. Nevertheless, it is a cosmetic beauty, with over $120k in documented restoration receipts with the work accomplished through the spring of 2011. THE PROBLEM: the engine was "cleaned and reassembled" with functional parts but was not "restored" or "rebuilt" with the result being that the engine DOES NOT HOLD OIL PRESSURE. Why in the world the owner/restorer would spend all this $ without installing a sound engine is beyond me. My cost is $30k and I'm trying to figure out what to do next. So, I would appreciate your comments on the market value of this vehicle "as is" and on what I should expect to spend to have the engine rebuilt to make it a meaningful "classic". There are 12 miles on the engine post-reassembly. Thanks!
TonyM | -- 02-12-2012 @ 1:00 PM |
Welcome. Nice looking car. TM
flathead4rd | -- 02-12-2012 @ 4:16 PM |
Could you be a little more specific about not holding oil pressure. Have you put a mechanical oil gauge on it to check for accuracy? What weight oil are you using? Lots of flatheads idle a less than 10 psi oil pressure, especially when hot.
ford38v8 | -- 02-12-2012 @ 5:45 PM |
I agree. If the pressure n eedle moves at all while at slow idle, the engine will ber happy. Anything over 20 lbs at 25 mph is good. Alan
Old Henry | -- 02-12-2012 @ 7:51 PM |
I agree with Alan. After having my engine rebuilt by one of the best in the country the oil pressure still reads low. He said mechanical gauge read normal. Could just be my gauge or sender. I've decided pressure is not as important as flow and figure if any pressure shows I've got oil flowing through and don't worry too much about pressure. I've put 20,000 miles on the engine with the gauge showing low oil pressure without any problems. I wouldn't worry too much about that. Certainly not consider rebuilding the engine again just for that. Old Henry (The older I get, the better old looks.)
trjford8 | -- 02-12-2012 @ 8:24 PM |
As others have said check the pressure with a mechanical gauge. Spending 120K on a restoration without rebuilding the motor tells me the previous owner had more money than horse sense. I suspect all he wanted to do was show the car and not drive it. There are those folks out there who trailer their cars to every show and don't drive them. It's a great looking 35 and $30,00K for a restored car is not out of line on price. Nice paint jobs today are $6000-8000. Upholstery is $5000-7000. Add in bodywork, tires, radiator, clean up of the running gear, and other miscellaneous parts, etc. you will spend another $7000-9000. Now add the purchase price of the original car prior to restoration and you easily get to $30,000. If you have to rebuild the flathead you will probably spend $5000-6000. If it's an original 35 motor you will have to have the main bearings poured by a shop experienced in building older motors. Again, recheck the oil pressure with a mechanical gauge and get back to us with the results. You may get lucky and not have to do anything but drive and enjoy your new treasure. This message was edited by trjford8 on 2-12-12 @ 8:25 PM
TomO | -- 02-13-2012 @ 7:24 AM |
Your car is very nice and well worth the money to rebuild the engine if necessary. I agree with the other posts that you get a mechanical gauge to check the oil pressure and post the readings here. Tom
stevenwham | -- 02-13-2012 @ 5:57 PM |
Thanks for all these comments .. I really appreciate the thoughts and advice. I will definitely get the mechanical oil pressure check soon. I drove the car today (for the second time) and noted the following: cold start with temperature around 40 F, the oil pressure read about 18-20. As the engine warmed up the temp dropped to 10-12 and continued to drop while driving around at about 30 mph, eventually settling around 5 (at 30 mph). At idle and relatively warm, the pressure dropped to 2 or so. New gauges. I'll get the mechanical check and report back. Thanks again for your comments.
TomO | -- 02-15-2012 @ 9:05 AM |
Steve, try removing the sending unit and cleaning the threads on it and in the block. The sending unit needs a good ground in order to give an accurate reading. You may have an 80# sending unit with a 50#oil pump. The sending unit should have 50 stamped on the brass fitting. If the 80# unit is installed, your readings would be normal with 10w30 oil. The 50# sending units are getting hard to find. Most of us use 20w 50 oil or straight 30 weight oil. Tom
stevenwham | -- 02-15-2012 @ 4:49 PM |
Thanks for your comments, Tom .. and others .. I'll do some evaluation this weekend. Steve
ford38v8 | -- 02-15-2012 @ 6:20 PM |
TomO, Good call oin the grounding of the unit, and also the 80 lb versus 50 lb units, but I will remind you that the original equipment 50 lb units had no marking at all. The markings came about only because the 80 lb units became available, in order to distinguish between the two. Alan
TomO | -- 02-16-2012 @ 7:43 AM |
Alan, thanks for the reminder. Tom
Texas40 | -- 02-18-2012 @ 9:50 AM |
I use Valvoline straight 50 weight oil (racing oil) cause if the engine was built to original specs, my engine guy told me you need the higher viscosity to mimic the oil used when new. Valvoline also offers a HD 40 weight oil. That HD 50 oil may help the oil pressure readings as well.
ford38v8 | -- 02-18-2012 @ 1:19 PM |
Texas40, You might consider getting a new engine guy if he told you that. First, 50 wieght was never specified when new, nor should it be used today to "mimic" the old oil. Modern multi-grade oil with detergent additives outperforms then best of the old formulations. Second, having high oil pressure doesn't mean your oil is protecting your engine. It simply means that your oil is thick and having a hard time snaking through the oil passages in your engine. You want your oil going to your bearings, not escaping through your high pressure relief valve. Alan
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4334 |
