1935ford | -- 01-25-2012 @ 5:45 PM |
I'm planning to replace the original steering box with a '37 unit. Besides four rivets, is there anything (such as welds) which secures the steering box mount to the frame? Thanks!
G Tosel | -- 01-25-2012 @ 8:14 PM |
There should be only rivets. I did the same change on a 36 Ford.
trjford8 | -- 01-26-2012 @ 7:53 AM |
There is a spot weld on the top of the bracket/frame that does hold the bracket to the frame.After you remove the four rivets you can pry the bracket loose. The spot weld breaks fairly easily.
1935ford | -- 01-28-2012 @ 7:34 AM |
Had removed upper rivets and heads of lower ones. Thought could pry the bracket out w/o fully removing lower rivets first. The spot weld explains lack of success. Thanks!
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4266 |
