santagary | -- 01-22-2012 @ 10:09 AM |
Are there any pics and instructions available for the installation sequence for installing window channel,etc. I have Mac's $80 kit, but I can't find any printed pics or help on this. Also, what is needed to remove the door opener and window wind without scr*w*ng things up on a 46 1/2 ton?
TomO | -- 01-25-2012 @ 8:02 AM |
To remove the handles, push the escutcheon away from the handle and you will see a small pin holding the handle on. Push the pin out and the handle will come right off. Glass removal is similar to the passenger glass removal shown on this link http://www.vanpeltsales.com/FH_web/flathead_servicelinks.htm I think that the glass run (fuzzy channel) is held in place by small flathead screws and some clips. The fuzzy strips at the bottom of the window opening are held in place by flathead screws on the door side and by staples on the molding side. Check with Dennis Carpenter to see if his kit contains instructions. If it does, return Mac's and order from Dennis. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4253 |
