Gene N. | -- 01-18-2012 @ 3:07 PM |
What yrs shocks will fit a 34 ford car The arms I do have Front and rear shocks Thanks guys
40 Coupe | -- 01-19-2012 @ 4:49 AM |
For the rear of the 34(inside the frame): The 33 and early 34 shock, as well as the later 34 to 35 rear shocks will work these styles come with and without adjustments. The 33-early 34 is smaller that the slightly larger 34-35 shock. The front shock mounts on the outside of the frame for 34 and the mounting holes are different than the 32 shock, the 35 front shocks have arms already attached that have the tapered hole for the shock link but for 35 there is a ball that mounts into the tapered hole and MAY be able to use this shock??? Otherwise the outside mounted front shocks from 33-34 only.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4237 |
