40cpe | -- 01-16-2012 @ 1:21 PM |
OK, I'll re-phrase my question. How do I replace the lock cylinder cover retaining spring on a '38 trunk handle? Thanks, Gene
TomO | -- 01-25-2012 @ 8:16 AM |
I don't know how the spring is held on the 38 handle, but on my 40 Mercury there was a brass sleeve that was pressed on. I just removed the sleeve, repaired the lock cover and pressed the sleeve back on. Tom
40cpe | -- 01-25-2012 @ 12:14 PM |
I think the '38/'39 handle is different. These have a stainless (rustless) steel skin that has to be removed to access the sleeve on the spring pin. I elected to drill the spot welds and remove the back housing to access the spring.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4234 |
