BOBS 35 | -- 01-07-2012 @ 5:50 PM |
HOW DO YOU INSTALL HOOD ON A 35 FORD, I HAVE THE COWL AND RADIATOR BRACKETS, AND THE SUPPORT RODS, I DON'T KNOW HOW TO PLACE HOOD ON THE BRACKETS, DO YOU HAVE TO PULL GRILL FORWARD ??
BrianCT | -- 01-07-2012 @ 7:38 PM |
I would unbolt the bracket at the cowl, slip the hood onto the front bracket and re-install the back bracket.
tommorookian | -- 01-10-2012 @ 2:01 AM |
Not sure about 35 but on my 36 what I did was fully assemble the hood side panels and center strip. The bracket on the radiator is scr*w*d on. A 2 man operation is to lift the hood with the back bracket stuck in the center strip over the radiator and walk it back. 2 screws in the back bracket and your done.
BOBS 35 | -- 01-16-2012 @ 10:38 AM |
THANK YOU FOR THE REPLY ON MY HOOD, NEVER SAW IT INSTALLING THAT WAY, IT WORKED, THANKS AGAIN
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4192 |
