heckertken | -- 01-05-2012 @ 7:48 AM |
Is there anyone who rewires /restores '39 horns? Thanks for any help
37RAGTOPMAN | -- 01-05-2012 @ 5:10 PM |
did you take the covers off and clean the points,to see if this fixes the problem of not working,? usually a good cleaning, gets things working again, lets hear how you made out, hope this helps 37RAGTOPMAN
TomO | -- 01-06-2012 @ 8:32 AM |
Wiring harnesses for the horn motors are available from many suppliers and can be easily soldered in place by any one with electrical soldering experience. Find a TV-Radio repair technician or a generator repair technician to solder them for you. The horns seldom need further work, unless someone has tried to adjust the contacts. They can be tested by connecting a heavy gauge (10 gauge) wire between the lead and the battery NEG post and between the case of the horn and the battery POS terminal. Tom
Chris.NZ | -- 01-10-2012 @ 10:46 PM |
Probably cheaper to buy a good pair on e-bay.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4184 |
