jal9846 | -- 12-30-2011 @ 10:03 PM |
Ran across a strange looking top load 3 speed attached to a G-series 6 Cylinder. Can anyone tell me what it is out of?
alanwoodieman | -- 12-31-2011 @ 6:41 AM |
that is the open drive shaft trans out of a 3/4 ton truck with a six cylinder engine. the gears are probably 29 tooth cluster and are quite low. The rear mount is what really makes it out of the 3/4 ton, if you had the rear axle it is what the dirt track guys used in their cars.
jal9846 | -- 12-31-2011 @ 3:11 PM |
Would the 1/2 ton pickup have the same type of transmission? or were there two types for the G-series engine?
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4171 |
