35Rich | -- 12-29-2011 @ 12:50 PM |
In an attempt to replace both the drivers side window and also the window guides, I discover that I cannot figure out how to actually remove the window and or the regulator from inside the door. I have disconnected the regulator from the door (6 screws)and I can disconnect the "rear" follower from its track but not the "front" follower. As a result I cannot remove either the window or the regulator from the door to make this repair. What is the secret to do this? Is it covered in a 35 manual? If so where do I get such a manual or bulletin? Also what is a good re-assembly procedure? Thanks 35 Rich.
bobv | -- 12-31-2011 @ 5:04 AM |
I just did this on my 37, not too bad when you figure it out. I also did the quarter window, same method. This info is from the service bulletins.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4164 |
