planojc | -- 12-29-2011 @ 8:31 AM |
What is the proper way to add fluid to a 51 Ford overdrive transmission? There are two filler plugs and they seem to be offset, so I assume you add fluid to the highest opening until it comes out the lower one. Thanks
supereal | -- 12-29-2011 @ 11:22 AM |
In the Borg-Warner OD, the transmission and the overdrive have separate oil reservoirs, and must be filled individually.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4163 |
