FFracer | -- 11-21-2011 @ 8:03 AM |
I have read a couple post's here about the new gas destroying the diaphragm in the pumps. I know my 33's pump is having problems but I have a 6v pump back by the tank so flip the switch and I am running. Does anyone make a new fuel safe re-build kit? And if the diaphragm fails will fuel be pumped into the crankcase (Like it can on the Chevy OHV motor?). I have no problem running the electric I was just wondering if the pressurized fuel is staying in the pump then to the carb. as needed, and not diluting the oil. Thanks, Chris
Cecil/WV | -- 11-21-2011 @ 2:07 PM |
If the diaphram ruptures, gas will fill the crankcase. Ken Isadore in Ct rebuilds pumps with ethanol safe parts and maybe Charlie Schwindler in NY. Shiny side up! Cecil/WV
supereal | -- 11-23-2011 @ 3:11 PM |
You can buy a rebuild kit from a good vendor like C&G for about $20. Lots of problems developed when alcohol was added to gas, and many vendors still sold non-nitrile kits that were on the shelves. Buy these parts from a high volume vendor to be sure they are "fuel proof". If unsure, ask, and tell them that if they are wrong, they will have to replace the parts.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4000 |
