239al | -- 11-20-2011 @ 6:10 PM |
I have a 1947 Ford and I'm in the process of installing a Columbia overdrive. My question is: will the vacuum control valve assembly (valve that uses two solenoids and mounts on the head) operate on 12-volts? If not, any suggestions on how to solve the problem? Maybe use a resister in the hot line feeding the valve assembly? I'd appreciate your comments.
ford38v8 | -- 11-20-2011 @ 6:51 PM |
Ask the expert: John Connelly, Columbia Two Speed Parts Reproduction Repair Axle Parts and Controls for the Columbia Overdrive Two Speed Axle 1935 - 1948 www.columbiatwospeedparts.com Alan
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3999 |
