markpa | -- 11-18-2011 @ 1:57 PM |
I have a couple of 60 hp water pumps that need replacing or rebuilt. Does anybody know somebody who rebuilds these? Thanks, Mark
supereal | -- 11-18-2011 @ 8:26 PM |
There are two styles of 60hp water pumps, and I don't know of anyone who is rebuilding them. They are quite different from the regular pumps. The last 60 we repaired needed a pump, and we found one at Little Dearborn in Minneapolis.
nelsb01 | -- 11-18-2011 @ 10:09 PM |
There used to be rebuild kits from Ford out there at swap meets. You'd see them every now and then. All they consisted of was a new spring, a impeller, and a gasket. The kits worked for either the early pumps (tappered bodies) or the late pumps (straight bodies). You might want to give Little Dearborn a call. Ask for Terry. 888-282-2066 This message was edited by nelsb01 on 11-18-11 @ 10:11 PM
1938cr | -- 11-21-2011 @ 8:28 PM |
I had my 60 hp water pump rebuilt by Daryl Fryer (909) 335-1418 (see ad on page 99 of current V8 Times). Very honest and great work. Good luck! CR
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3991 |
