GORDON | -- 11-05-2011 @ 11:27 AM |
Hi. Can any body tell me were I can get a better quality pump stand for my Pilot. it is like a 38 and has the standard pump,The threads have gone again ,this is the second time this has happened ,a steel one would be good, Thanks for your help .Gordon.
kubes40 | -- 11-05-2011 @ 11:47 AM |
I've got a real nice one with great threads. Not steel though... If you keep pulling the threads out, I might suggest the bolts you are using are too long and / or you are over tightening the bolts. email me at: kubes40@att.net. I can send you a photo if desired. Mike This message was edited by kubes40 on 11-5-11 @ 4:51 PM
alanwoodieman | -- 11-05-2011 @ 12:33 PM |
could you have the wrong length fuel pump push rod? do you have aluminum intake? if so push rod is dhorter than the cast iron intake and this can cause the stand to break apart
GORDON | -- 11-06-2011 @ 12:14 PM |
Thank guys, I can get same a before local,I will try and be more carefull .Cheers Gordon
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3937 |
