planojc | -- 10-25-2011 @ 2:50 PM |
What is the best way to remove the top bolt on the overdrive solenoid? Would loosening the transmission cross member lower it enough to access the bolt? Thanks
supereal | -- 10-25-2011 @ 3:08 PM |
If your car is a convertible, the extra brace on the cross member may be at fault. If it is bolted, you may be able to remove it. Otherwise, support the transmission/overdive unit with a jack and lower the crossmember enough to get at the bolt, and be able to turn the solenoid to release the plunger from the balk ring in the OD.
planojc | -- 10-25-2011 @ 3:45 PM |
Thanks, got it out.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3889 |
