silverchief | -- 10-21-2011 @ 2:08 PM |
Should original equipment on my 49 flathead be an A circuit or a B circuit generator? Anyway to tell other than the testing procedure?
TomO | -- 10-22-2011 @ 7:42 AM |
Ford generators are "B circuit". The field is grounded inside the generator. A "B circuit" generator will produce full voltage when the field and armature are tied together. An "A circuit" generator will produce full voltage when the field is grounded. Tom
silverchief | -- 10-22-2011 @ 9:19 AM |
Thanks Tom, I had it backwards.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3873 |
