Savvy | -- 11-30-2009 @ 8:29 PM |
After the large yellow wire exits the dash harness, it passes through the ammeter. Which post on the resistor/fuse block does the wire terminate? Thanks in advance. Cheers!!
TomO | -- 12-01-2009 @ 6:40 AM |
It goes to the source side of the fuse block, the same terminal as the ignition switch. The ignition switch wire is yellow with a black tracer. Tom
Savvy | -- 12-01-2009 @ 7:11 PM |
Thanks!
TomO | -- 12-03-2009 @ 7:29 AM |
You are welcome. you can find a wiring schematic for your car at: http://www.vanpeltsales.com/FH_web/flathead_home.htm Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=387 |
