sunflower | -- 10-19-2011 @ 1:41 PM |
Where can I purchase a low melt grease for my 35 Ford water pumps or a good lube and how much do I use? Thank you. sunflower
alanwoodieman | -- 10-19-2011 @ 4:02 PM |
Mystic JT 6, virtually water proof and flows at low temp, some guys also use this in the univeral joint.
37RAGTOPMAN | -- 10-19-2011 @ 4:33 PM |
trailer places sell a water proof grease for wheel bearing, check if you think this might work for you, just do not use too much, might get in the coolant, also use water pump lube in the coolant system, this is also another way to help the bushing from wear, hope this helps 37RAGTOPMAN
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3864 |
